Home > Maintenance & Mods (L322) > Anoying Rattle |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Dust shield behind the brake disks ?
6th Apr 2013 11:07am |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Thanks
6th Apr 2013 12:22pm |
The garage where I bought the car from did mine. They just had it spot welded back, and its still fine 18 months later.
6th Apr 2013 12:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
its a common problem which has been mentioned before...cant remember the exact solution but if you do a search i'm sure you'll find the threads.. ... - .- -.
6th Apr 2013 1:02pm |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
undo the two little bolts that hold the cover on then slip a big washer in there, fiddly but it works. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
6th Apr 2013 1:31pm |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
Or if they are too corroded, cut them off and buy new ones. Cutting a small section out if your new shields means they can be fitted without removing brake calliper and disc, just make sure you treat the bare metal edge with paint before fitting. See dan @ duckworth for a price, they are only a few quid. |
6th Apr 2013 3:21pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
You would think given their location that Landrover would have used corrosion proof materials Present :2008 TDV8 HSE
6th Apr 2013 7:07pm |
