Home > Technical (L322) > Pre heater followed by Flat battery
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Did anyone use their preheater during the cold weather then couldn't start the car. I bought my car May last year and one of the things I had to do was to replace the battery so I did; how do I know whether I have bought a suitable battery for the preheater to work.
Post #182528 12th Apr 2013 12:23pm
what battery did you buy? ... - .- -.
Post #182530 12th Apr 2013 12:36pm
Elena
Hi Stan
I did a search for my car and it came up with the Bosch S3 90 amp, stocked locally and I was really desperate for the battery so I bought it.
Post #182537 12th Apr 2013 12:57pm
wrong battery Elena, it should be a bosch s5015, type 020 with a 920 cca not 720 cca [017] as you have ...this battery will probably be ok in the summer months but it will let you down when it gets cold... ... - .- -.
Post #182538 12th Apr 2013 1:06pm
Elena
Thanks Stan, wish I had asked before I bought the battery but as with most women I was much too impatient to wait but I will get this sorted now, thanks again, cheers Elena
Post #182539 12th Apr 2013 1:13pm
GraemeC
Search the forum and you'll find a couple of threads re. installing the Bosch battery
The battery is larger than the original and the threads contain some useful tips on getting it to fit! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #182541 12th Apr 2013 1:23pm
sometimes needs must...
as Greame says there is info re fitting in the wiki. ... - .- -.
Post #182542 12th Apr 2013 1:26pm
Elena
Thanks guys, just found the battery i need and the helpful info on replacing it, cheers
Post #182549 12th Apr 2013 2:07pm
