Home > Technical (L322) > Brake Servo fault
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Brake Servo fault
Hi all my 05 TD6 has developed a brake fault! after 3 to 4 seconds applying the brake it goes hard (we know the jokes lol) when i run the engine (with bonnet up) then switch off and listen to the area where the servo is i can hear a hissing. new servo i think? just wondered if you guys have replaced one and how long it took.
Still love it!!!!!! If i could would you!!!!
Post #182743 13th Apr 2013 2:58pm
Diseasels don't have a servo it will be your vacuum pump . 2008 MY Supercharged
Post #182744 13th Apr 2013 3:04pm
Yes they have servos, they also have vacuum pumps.
Worth checking the vacuum hose adjacent to the servo, you might be lucky it could just be leaking somewhere. possibly the connection to the servo.
Post #182747 13th Apr 2013 3:14pm
thanks will have a look tomorrow If i could would you!!!!
Post #182807 13th Apr 2013 10:11pm
Right I first took pipe off the vacuum pump to make sure that works and all fine, I then checked all pipe work again good. Then I got the wife to sit in the car with it running and for her to switch off the engine and then press the brake, a big woooosh sound and then no brakes. Ordered new servo and removed old one ready for it arriving, such an easy job if any one needs any info then just drop me an email.
Russ If i could would you!!!!
Post #183225 16th Apr 2013 3:12pm
ebajema
Have a little look around the forum using search. I remember something similar being reported on here (TD6 engine) and that it was considered "normal". MY 2010 5.0 SC Galway green and sand interior!!
Post #183227 16th Apr 2013 3:26pm
