Home > Maintenance & Mods (L322) > Transmission Failure Warning
Gramrugby
Scotland 2006 Range Rover Autobiography 4.2 SC V8 Tonga Green
My wife tried to start the car this morning, turned the key and nothing. Transmission fault indication on the dash. Battery appears to be ok, ie all lights are strong etc. Problem is the cars in Edinburgh and I'm in London until the weekend.
Any thoughts ?.
Post #183005 15th Apr 2013 11:41am
Budgie
More than likely the battery.
I had similar, the lights & everything works but there's not enough power in the battery to turn the starter and in my case I didn't even get a "click" from the starter motor.
Jumpstarting off another vehicle will get it running but the powerpacks won't unless it's good, high amp, pack.
Post #183007 15th Apr 2013 11:47am
...and after getting a jump start make sure you turn the steering wheel fully left then fully right.. ... - .- -.
Post #183009 15th Apr 2013 11:48am
Budgie
I forgot that bit, Stan, otherwise you end up with a Christmas tree for a dash. Thumbs Up
Post #183010 15th Apr 2013 11:51am
Gramrugby
Thanks guys, it sounds as though the battery - hopefully! is the culprit as that was exactly as she described the fault.
Post #183011 15th Apr 2013 11:52am
Gramrugby
Any recommendations for a replacement battery ?. It's for a 4.2 autobiography supercharged 2005
Post #183388 17th Apr 2013 5:05pm
ebajema
Get the biggest you can find, I believe the 110 AH Bosch is a big favourite of the people on here for Euro Car Parts. There will be a discount code here somewhere as well, just do a search.
I could only get 100 AH but would have preferred 110 as well. MY 2010 5.0 SC Galway green and sand interior!!
Post #183395 17th Apr 2013 5:26pm
Gramrugby
Thanks, battery being collected tomorrow.
Post #183489 18th Apr 2013 7:10am
Gramrugby
It was the battery and all ok now. Thanks for the replies and advice.
Post #184386 24th Apr 2013 7:36am
Thumbs Up ... - .- -.
Post #184410 24th Apr 2013 9:45am
