Home > General > Well I've lost my breakdown virginity.
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Just driving back home tonight and got 5 miles away from home when fuel inject system flashes up and I lose all power, power steering, power assisted braking the works.
I've had the inspection cover off and bashed the fuel pump. But to no avail, I can't see any fuel in the engine compartment pipes or in the inspection filter dome.
Big Cry Big Cry Big Cry Bushy
2003 RR Vogue Monté Carlo Blue
Post #184328 23rd Apr 2013 10:09pm
Mr Tee
After the 3rd time , I bit the bullet & joined the AA
Post #184333 23rd Apr 2013 10:14pm
Bushy513
Already taken the bite, otherwise I'm not getting home tonight, lol Bushy
Post #184335 23rd Apr 2013 10:16pm
Mr Tee
Best of luck, once the cars running better you'll forgive the minor discretion! Might have a sore arse from the repair bill though Whistle
Post #184342 23rd Apr 2013 10:21pm
Bushy513
I've got 4 months used warranty left so hopefully will be covered with that. Bushy
Post #184370 23rd Apr 2013 11:14pm
Any update at all?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #184478 24th Apr 2013 5:06pm
Flashman
Hopefully he is not still out waiting for the recovery van. Tom
Current Drive
Previous Drives
Post #184489 24th Apr 2013 5:38pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
If he is with the AA that is very possible! Twisted Evil
Post #184517 24th Apr 2013 7:25pm
Bushy513
AA man couldn't sort it out either, I'm trained as a mechanic and pretty much told him, he wouldn't be able to fix it lol.
So got recovered to local land rover stealers and now I'm waiting for the outcome.
Big Cry
I'll post updates when I get some info. Bushy
Post #184551 24th Apr 2013 9:33pm
Prop
I had almost exactly the same symptoms as you describe on my TD6, only difference was if I left the ignition on for 2 mins with the fuel pump priming and did this a couple of times it would eventually start. Anyhow to cut a long story short it only occurred when the fuel was down to about a quarter of a tank. Happened a couple of times while I was diagnosing the issue. Turned out to be a faulty in tank fuel pump which was not siphoning fuel from the left saddle side of the fuel tank. Replaced pump and now its been fine. Obviously yours could be some other failure but thought I would let you know just in case it helps.
Post #185140 27th Apr 2013 6:12pm
Bushy513
It's still at the stealers atm but they are changing the filter first, before going back to the in tank pump. Personally I hope it is the pump otherwise the warranty won't cover the filter, and I'll end up paying over £100 just to have them replace a 5 minute filter. Censored Bushy
Post #185144 27th Apr 2013 6:20pm
If its the intank pump could you ask to keep the old one as i may have a use for it if thats ok??
Fingers crossed for the both of us Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185195 27th Apr 2013 9:23pm
Bushy513
Sure no problem mate. Bushy
Post #185245 28th Apr 2013 9:25am
Cheers fella Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185253 28th Apr 2013 11:01am
Bushy513
It's the external pump Kingpleb, I don't know if thats any good to you? Bushy
Post #185475 29th Apr 2013 1:06pm
