![]() | Home > In Car Electronics (L322) > Where should I slip my tool? |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244 ![]() ![]() ![]() |
I am changing the connectors on my headlights and PDC loom for a conversion and want to remove the wire plugs from the connectors. I have attached the two pics, one of the new headlight plug and the other from a 2010 PDC loom.
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
This post is doomed I feel to a large amount of innuendo with a title like this |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Yes, I'm sure someone will give you one. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
On both connectors I would have thought that the inner part should release somehow and come out forwards, exposing the back of the connections? Access to the back of the connectors should provide obvious release of individual pins? Don't have experience of this, just a suggestion.... .
Perhaps a spectacles screwdriver set (that's what I call them) has the length, strength and skinniness needed .
I've tried A&F screwdrivers (watch repairs etc) and they are not long enough and I am worried they will snap, hence wondering if there is a special tool to make it easier. Tom
You need a 4-6" pick then go in where the red arrow is, touching the metal with the point and push to the rear, then lift the plastic flap whilst pulling the wire... Simples |
Nice one Craig! Tom
