Home > Maintenance & Mods (L322) > FFRR. Only got it yesterday - Oil on the drive this morning.
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
I'm in the same boat! Stil haven't got mine back! There where two leaks. One from the rear differential another from the gear box sump. They are struggling with the removal of the rear differential as some of the nuts have totally seized up.
In summary 3 days without a fix. Courtesy car is however a brand new freelander. It's pretty decent to be fair but not my FFRR.
Post #186237 2nd May 2013 8:51pm
Trev18
United Kingdom 2005 Range Rover Vogue SE Td6 Zambezi Silver
Update 3.
After 8 days without it..... its back... Drive Shaft issue well and truly fixed... So they say... I will be checking the drive in morning...
I am smiling again....... Laughing Thumbs Up
Just taken 10 mins to update the new sat disk with a 2011/12 version...
Car mats, luggage cargo nets and trim guards will be fitted this afternoon..
Well chuffed...... Mr. Green
Trev
Post #187210 8th May 2013 2:13pm
All good news then Trev Smile
Crooked i guess most dealers aren't as mechanical as they used to be as a seized nut shouldn't take too long to remove...
they should try a Citroen C5 Rear sphere that is 11years old.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #187216 8th May 2013 3:41pm
ebajema
That's because Citroen uses rust instead of Loctite to secure nuts and bolts Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #187227 8th May 2013 4:40pm
Dont be silly, JLR would never waste such money on loctite unless it was from lidl Wink
Citroen using rust... I wish! they use Metallic bonding due to age Sad
Frigging nut jobs making parts out of Alu!! pfft the sheer audacity of it! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #187228 8th May 2013 4:45pm
Trev18
Update 4..
More oil on the drive........ size of a thumb nail in two hours... leaking off the sump guard same place as last time... Just rang the garage and let them know..
Sad state of affairs that they said it was fixed..... and obviously not....
Will...
Are you available Tomorrow night...(Thursday) as per our PMs to give it the once over..
Trev
Post #187250 8th May 2013 6:21pm
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Sorry to hear that Trev!! Hope they will be able to resolve it soon for you... Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #187252 8th May 2013 6:33pm
crookedm
Sorry to hear that Trev. My final bill was £552 + 179 (they wanted 770 negotiated an hour labour plus the part). It was the rear differential. Plus the gear box sump. Maybe worth checking those Sad
Post #187281 8th May 2013 8:48pm
Pm RSVP'd Smile
Post #187313 8th May 2013 11:05pm
Trev18
Final Update
Nearly had the FF for a month now.. its still the best car I have ever owned.. Mr. Green
Wasn't happy with some of the answers the dealer was telling me so
I decided to have an "independent" check it over.. for a general condition check and possible warranty issues and for £95.00 the following was identified.
** Full diagnostic check (remove all of the past faults and identify if any recent ones needed attention) All cleared as no issues found
** Outer CV Boots clips insecure. Big Cry
** Wiring LHF headlamp is un-insulated
** Various Suspension rubbers are starting to show signs of age, but not considered excessive.
** Rear Brake pipes are showing signs of corrosion and may need renewing in the near future.
** Rear Wheel arches showing signs of rust (Quote of £45.00 to sort)
** Under body would benefit from a steam clean and wax
Not bad for a car that is nearly 8 years old.
Been in the garage again today....to have the 2 front CV boots sorted, they where leaking grease onto the inside of the wheels.
A bit of tape for the wiring - The others I will do later on when required
Had a top of the range Mazda 6 has a courtesy car this time.. Laughing
I consider I have got myself a very clean and technically sound FFRR which will hopefully be fault free going forward... If not still got 11 months warranty Thumbs Up
Silver FFRR Vogue SE 55 plate. with full service history and 56k
Once again thanks to the forum and Will for all the help and advise I gained before and after the purchase..
Trev
Post #190174 23rd May 2013 6:53pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
In days of olde we used to say that a Land Rover only stopped leaking when there was no oil left Shocked Rolling with laughter The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #190351 24th May 2013 1:53pm
Budgie
In days of old we used to say Land Rovers don't leak, they just leave their Trade Mark!! Laughing
Post #190356 24th May 2013 2:07pm
