![]() | Home > In Car Electronics (L322) > Retro fit reversing cam |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66 ![]() ![]() ![]() |
Thanks Craig that looks like an ideal solution - any suggestions re where to get a suitable camera from? Ideally I would like to get one as close to OEM as possible....esp. if it can use existing wiring loom... but nothing on eBay so I am guessing OEM are not easy to come by...
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
http://www.fullfatrr.com/forum/topic4621.html African Bush Junkie ... in London!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
do a search Jerry, loads on the forum re this.. ... - .- -.
I did try search first, I promise |
put "camera" with the quote marks in and you have 6 pages to troll through , not all relevant but some are.. ... - .- -.
Thanks DR I did read that thread but (1) it is for a car that already has a camera installed and (2) the author was unable to tell us the make of camera he bought.... Cheers Jerry |
OK after some further reveiwing of the search results (thanks Stan), it appears that in order to have a camera that will see the towbar I need to do something other than the OEM install - as the OEM can't see the towbar!
on some of the ebay listings selling these number plate cameras, they give the dimensions ..its a case of removing your number plate light, measuring it and compare to the ebay ones. ... - .- -.
OK will do that - in the meantime if anybody has been there/done that, please let us know!
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Don't know if this would be suitable - should hook up to all the BMW kit ok....
Jimbo73 Member Since: 11 May 2013 Location: Wokingham Posts: 1 ![]() ![]() ![]() |
Hi Guys,
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
I have mounted a tiny surface mounted camera below the rear bumper. Wouldn't know it's there unless you were looking, great rear visibility, ok in the dark with reversing lights, and looks straight over the top of the tow ball making hitching easy...
that's a neat little camera, good job..have you any install pics? ... - .- -.
