![]() | Home > In Car Electronics (L322) > Another Bluetooth issue |
Al Hornby Member Since: 19 Mar 2013 Location: Horsham West sussex Posts: 18 ![]() ![]() ![]() |
Hi Guy's
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
i read somewhere that the venture cam might take 'priority' over the phone..i'm not familiar with your year but try disconnecting or taking the venture cam out.. ... - .- -.
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
I had this after my BT upgrade from the same place. I have an 07 TDV8 VSE too, not that that should matter.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Had similar with my2005. First check plug on the bluetooth module for water damage Then i found that pairing and deleting the pairing a couple of times seemed to sort it.
Hi Chaps.
Which Phone and OS is the phone running on please as that could be a clue?
Hi Kingpleb.
No worries Al |
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
Did you fix this? As mine had a similar problem which I fixed by changing a setting using the IID tool. |
Hi.
Many thanks for the info. As I said I havent got an IID tool yet but I may see if I can get one at Billing this year if Britpart are there.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I have this all the time, IPhone 4S, all I do is select the Off Road Screen and press the on screen Venture Cam Icon. Works every time except if I'm a little impatient and the screen will flash "phone disconnected" as it had already made the connection. If that happens I just press it again.
Hi Geoff.
