![]() | Home > Technical (L322) > Sport wheels on a FFRR |
coko Member Since: 13 Sep 2009 Location: ... searching ... Posts: 107 ![]() ![]() |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Thanks Coco!! Mike |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Will they clear the brake calipers? I am looking for a spare set of wheels and some of the sellers (admittedly only ebay) are saying that some 20 inch wheels won't go over Brembo equipped cars.
Alias Member Since: 14 Oct 2009 Location: Zurich Posts: 70 ![]() ![]() |
Officially, 2003-05 Range Rover wheels are incompatible with later models and vice versa, and all RR III wheels are incompatible with LR3 and RR Sport wheels. RR III wheels have a 57 mm offset, whereas 53 mm is used on the LR3 and RR Sport. Also, the earlier Range Rover lug nuts had square ends and the D3/LR3/Sport ones have tapered ends (see photo at right). In 2006, Range Rover wheels were redesigned to accept the RR Sport and LR3 lug nuts. However the 57 mm offset was retained.
