Home > Technical (L322) > Loss of Audio
Dolphinboy
Bogie, I have a spare amp. It is a LEAR (BMW) but works. bought it in error as it was the wrong one for my model. It has 2 ports for the wires. I will try adn photo it adn send you or you could PM me photos of your connection box so I can see if it matches.
if it does you can have it at cost. Thumbs Up
Post #55375 18th Mar 2011 11:23am
bogie
cheers, let me have a look at the weekend at mine and see if it looks like it will do the job ...a spare will be handy for testing if nothing else ! cheers
bogie
Post #55465 18th Mar 2011 7:17pm
bogie
OK, had a good check of everything in the rear electronics compartment.
cleaned all connections with contact cleaner etc and double checked all were firm. None were corroded
it dosent seem damp in there, but put a couple more bags of silica stuff in there, just to be sure
so will try it this week, usually it takes 30mins into a journey before it starts playing up - random NAV reboots and then radio cutting out, but leaving power light on. Switch on/off again after a min or so and it comes back ...for a few mins then repeats
The amp IS a LEAR model anyway, XB000030 part number (I think) so if it still plays up this week may have to purchase a spair Smile cheers
bogie
Post #55715 20th Mar 2011 5:05pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I'm going to out myself as I now also have this issue - this thread may be contagious!
Ok my findings so far.. I lost DSP on occasions, some times greyed out. LED on Radio knob always ok.
After some suggestions last time it happened I hit the blue tooth button on my Nokia handsfree.. nothing.. then again.. the bluetooth started to ring my last call.. (at 620am! - doh), hung up quick. What do you know sound returned Confused
Don't know if this is a indication of the problem or a on the road fix.
I also previously let the sat nav shut down, pulled fuses for the radio and sat nav. Disconnected the battery for 15 min and pulgged all back in, seemed to stettle for a few days then.
Next job.. pull the boot tray and trim and check the wiring for inaccessible silver box (forgot which but detailed further up the thread here.)
Will post any solution if I find one. Evil or Very Mad 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #55725 20th Mar 2011 6:18pm
bogie
@dolphinboy
sent PM, defo need an amp if yours is the right p/n drop me a line cheers
bogie
Post #56803 26th Mar 2011 2:14pm
Dolphinboy
@bogie. will do pictures today and send asap
Post #56817 26th Mar 2011 4:19pm
elpeede
Well since giving my Nokia BT handsfree a work out (rarely use it) its been OK. Is there a relay in the amp I wonder... maybe its my nokia unit Confused 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #56997 27th Mar 2011 8:12pm
