![]() | Home > Maintenance & Mods (L322) > Front Brake pads fitting (TD6) |
Same as any other vehicle with pads, just make sure you have the car supported properly before removing the wheels |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
this might help a bit Mikey,
This is for the rears, much the same process
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543
Thanks for the input guys. No longer FF owner but still interested. Present car Jaguar XE
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Mikey you can pop over to mine if you want this weekend and we can do them? Doodle to do |
Yes, was an easy job in the end, apart from removing and refitting the front near side wheel. It looks like the garage that replaced the driveshaft some months ago damaged the stub slightly and then had to force the wheel on. No longer FF owner but still interested. Present car Jaguar XE
