|  | Home > In Car Electronics (L322) > Rear camera 2005 square headlights, touch screen |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      |
 Hi, I've done a search and found conflicting info about how retro fit a reversing camera into a 2005 square headlight, touch screen model. Depending on what I've found, it can't be be done, it can be done but you need to configure the head unit to allow the aux input, it can be done and you don't need to do anything other than connect power to reverse light and connect the input to the head unit
|  4th May 2013 11:46am |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | sorry just read your post again, ok you have a 2005, no prob,,, but that camera on your link wont fit, thats designed to go in your number plate lights and it is not a straight fit...get a camera to fit under your spoiler, you need a ntsc camera, do you have a tv tuner... V8 facelift Range Rover Autobiography 22" wheels.
|  4th May 2013 1:11pm |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      | Thanks, I have an analog tuner I assume as I can't get tv pictures, can the input connect into that? | ||
|  4th May 2013 3:47pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | with one of these
|  4th May 2013 5:55pm |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      | Ok thanks or the info, however isn't the 2005 touch screen the most system and the eBay item is for I-bus. | ||
|  4th May 2013 6:12pm |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      | Has no one fitted a reverse camera to a 2005 touch screen, square headlight range rover? Your help would be appreciated I don't want to buy incorrect parts | ||
|  7th May 2013 11:51am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | i looked into it and found that the only way to get the screen to switch on when reverse gear was selected was to get an after market module which cost approx £400 or maybe get it switched on in the ccf . ... - .- -.
|  7th May 2013 12:01pm |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      | Thanks Stan, I'll guess I'll give it a miss then....£400 seems too much money just to have a reverse camera | ||
|  7th May 2013 12:07pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | just remembered that there was a company selling modules for about £150 said to be ok for the fullfat but there was doubt whether it would do the job..i'll try and dig up some info.. ... - .- -.
|  7th May 2013 12:11pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | it was a gvif interface that gave you a dvd input and camera when reverse was selected but as far as i can remember i couldnt find it for the fullfat , only for the sport and evoque.. ... - .- -.
|  7th May 2013 12:17pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | this might help.
|  7th May 2013 12:20pm |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      | Interesting reading however still pretty expensive IMO, I guess the sensors will just have to suffice, thanks anyway | ||
|  7th May 2013 12:36pm |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244      | I have not installed the camera, but I have a pre facelift touchscreen L322 and you can activate the camera mode using the IID tool.
|  7th May 2013 1:00pm |
| Robbieowens Member Since: 19 Mar 2013 Location: Wirral Posts: 64      | That's better news, just need to find an auto spark who has the IID to turn the option on and find the camera, do you definitely need the rear spoiler with camera or can you retro fit any camera in? Perhaps in the rear bumper? | ||
|  7th May 2013 1:04pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
