Home > Off Topic > iPad Users - WiFi Connection Help Please
Bloody f****ng thing won't connect to my wifi at home.
It sees the wifi and acknowledges it's there and has clicked on it, but that rotating circle whatsits just churns and churns away with no connection. So I'm permanently on 3G.
I've rebooted 3 times. No luck. I've reset the wifi. Nothing. I've done everything Apple recommend and still nothing. It just churns and churns. I've taken the cover off and moved around the house and no improvement there either.
My wife can connect on her ipad Mini easily. My phone, however, seems to be suffering similar problems.
So, to recap, my wifi likes my wife and it doesn't appear to like me.
Any suggestions as I'm close to throwing the bloody thing in the bin. Sad Si. <This is my name.
Post #187663 10th May 2013 7:59pm
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Have you tried to connect it through another WiFi network to test if it would connect then...? I recall I had a similar issue a while back and then when I connected to another WiFi, it worked. I disconnected from that network, selected my own WiFi again and it connected without any problems. Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #187665 10th May 2013 8:12pm
None available from here. I could try on Monday when I get to work as there's free wifi there but I really don't want to wait that long.
Tempted to switch the thing off overnight, reset my router and see what happens in the morning.
It was working fine yesterday and hasn't been touched in between. Si. <This is my name.
Post #187667 10th May 2013 8:18pm
MikeG
That may do the trick... Make sure to first switch off your wireless option on the iPad... Then tonight switch everything off, iPad and Router, and tomorrow morning start up the Router and then the iPad followed by the wireless function on your iPad. We have it sometimes as well that for no reason they don't want to connect and switching everything off normally works. Good luck!! Mike.
Post #187670 10th May 2013 8:38pm
You say reboot is that the full reboot on and off button held in at the same time as the home button , and before hand switch off the Wi Fi on your iPad
Post #187672 10th May 2013 8:51pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Achhh Bellini I would just throw the f*****g thing in the bin!! Laughing Laughing
Post #187673 10th May 2013 8:58pm
Laughing Laughing Laughing
You're not a bin man in my area are you? Si. <This is my name.
Post #187674 10th May 2013 9:04pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Where it brings up the list of available wifi connections choose 'Other...'
Then put in the name of your network eg: 'Netgear' or whatever yours is called then it asks for 'Network key' put that in and you should be good to go.
You can find the name of your network usually on the side if your router under 'SSID' and usually the network key will be on there too.
Essentially your adding the settings manually. I had to do this after a firmware revision a few months back.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #187675 10th May 2013 9:06pm
Settings... Wifi.. Choose a network... Click on the arrow next to your network... Is dhcp highlighted? Does it have an ip address? Previously..
Post #187676 10th May 2013 9:07pm
