Home > Technical (L322) > Passenger rear door won't unlock. Urgent help please.
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi,
The door will not unlock at all, the only way to open it is to reach around and pull the handle.
The fob nor the button inside will unlock it but it does lock on both.
Slight urgency due to it being the door in which we have our baby seat (Baby is due any day now)
Thanks
2003 Range Rover.
Post #188486 15th May 2013 5:55pm
there are 2 cables in the door, one connected to the lock mechanism on the inside and one on the outside..sounds like one has broken which means door card off and replace.. ... - .- -.
Post #188495 15th May 2013 6:59pm
Budgie
Sounds more like the lock actuator than one of the cables if the button doesn't come up using the fob or lock/unlock button.
It's still a door card off job though.
I found a couple of units on the Bay of E for £50 including the cables. Wink
Post #188500 15th May 2013 7:16pm
rich89
So, door card off jobby and inspect?
Post #188503 15th May 2013 7:29pm
Correct. The same thing happened on my old '02 recently. My repair was, for various other reasons, to buy a newer model.
I've always been curious what the problem was, though. Thumbs Up Si. <This is my name.
Post #188504 15th May 2013 7:32pm
rich89
Haha,
I will have a look over the weekend. (if the baby hasn't arrived)
Will keep you updated if it is something obvious.
Post #188512 15th May 2013 8:04pm
rich89
It seems the problem is intermittent. It will work one time, lock it and try again and it doesn't work!
Took the door card off but could see anything obvious, could it just be a fault with the main unit in the door?
Post #189052 17th May 2013 10:21pm
robjp
Wales 2004 Range Rover Vogue Td6 Zambezi Silver
I've got a similar fault on the driver's door on my FF. Sometimes the door will unlock, sometimes the button just 'twitches' and it fails to unlock. Always locks though. Had the doorcard off a few weeks ago, but I can't see anything obvious either. My plan was idiot-proof ...
Until someone designed a better idiot
Post #189056 17th May 2013 10:54pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
^ Same here for my rear N/S door, most of the time it wont unlock... but if I lock and unlock several times in a row it will eventually work.
Looks like a drop of oil might fix it, but when I had the door card off I couldn't see where to put it.
Post #189057 17th May 2013 11:04pm
JarrahJack
Australia 2003 Range Rover HSE Td6 Zambezi Silver
The solution is to buy a new locking mechanism. It is possible to repair by drilling rivets out of the mechanism and replacing one of the tiny motors (which would have failed), but a new mechanism is less than US$100 from memory, note that they are specific to each door and the part number has been superceded a few times. 2003 TD6 HSE, Zambezi Silver, Navy Trim.
Post #189068 18th May 2013 3:53am
Note to all... Once these symptoms start, investigte quickly and if your lock is at fault get it changed immediately...as one day it will deadlock itself and that will be a 10x harder job! You have been warned gentlemen... Thumbs Up
Post #189086 18th May 2013 9:03am
I had a problem with the passenger door.
Sometimes it would unlock sometimes not.
My solution was to gently spray WD40 down beside the pop up button until it dripped out of the bottom of the door. Problem solved, never been back to it in over a year.
Post #189090 18th May 2013 9:30am
rich89
Is it an easy job to change it?
Post #189102 18th May 2013 10:32am
A bit fiddly but easily DIY do-able... Thumbs Up
Post #189108 18th May 2013 11:05am
rich89
I tried this earlier and it seems to have worked a treat.
Locked/unlock loads of times and it unlocked everytime!!! Very Happy
Post #189290 19th May 2013 9:42pm
