![]() | Home > Technical (L322) > Key update |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35839 ![]() ![]() |
wiki,
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
Thanks Stan. I had seen the Wiki but my problem is slightly different.
member Daveo is the 'key' guru here , give him a pm or have a look at his posts.. ... - .- -.
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
Get a genuine one - The sync procedure can be done yourself. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi, if you only have the one key then your options are limited, you can smarten up your original key with a new case,swap the electrics and chip over and get it cut by timpsons and away you go..if you are looking for a new key then you will need to ether go to the main dealer and that will cost you 200 plus for a new key or i am waiting for my new programer that will programe the early style keys,
elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 44 ![]() ![]() ![]() |
2008 TDV8. I lost a key a couple of weeks back. No problem as I have an IID tool. Except yesterday I lost the other one.....
contact bushey [LR KEYS] site sponsor....he knows all about keys so he'll give you sound advice... ... - .- -.
