Home > Technical (L322) > Weird EAS symptom
RugbyXV
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Baltic Blue
Weird EAS symptom
Ok, new engine in and a couple of flashing EML's which I'm fine with as the motor is running great and will have the codes read tomorrow. However, I have reset the EAS a couple of times with my RSW module and the battery lock to lock too, but when I go over 30 the dreaded "Air susp inactive" comes up. Any ideas or am I doing something wrong? It was fine before it was off the road for 3 months...
If I reset the pump comes on, it goes to the ride height and seems great until I hit 30. The fault that I read from the RSW module said CAN bus fault but then I read the lock to lock should clear that. Stumped now..Still, grinning like a Cheshire Cat at driving the beast again.. Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money!
Post #190830 27th May 2013 8:24pm
you havnt put it in low range by accident have you.. ... - .- -.
Post #190831 27th May 2013 8:25pm
ebajema
Sound similar to what another forum member has. Most likely cause I heard there was one of the height sensors not in perfect shape anymore. Now you need to try to find out which one. Maybe have a look at the values they are returning and see if one is going (almost) out of range. MY 2010 5.0 SC Galway green and sand interior!!
Post #190832 27th May 2013 8:36pm
