![]() | Home > Technical (L322) > Droning noise like cooler fan when stopped in 'drive' |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Have you 20" wheels on? |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
This is normal, it even states in the manual not to leave the car in D for long periods of being stationary.
More modern cars actually select N automatically when stationary without you knowing because of this permanent loaded state, it's all very clever and beyond my understanding, but I believe the main reason is like I stated above you'll use more fuel if you leave it in gear as the car will always be trying to pull forward slightly. So in a aim to ever increase MPG new boxes do this auto-switch. Bushy
dalziel Member Since: 11 May 2013 Location: Harrogate Posts: 57 ![]() ![]() |
Just responding to PaulB question, it has 22" wheels fitted but I'm wanting to sell these and return to 18" |
I noticed a difference in vibration at standstill when I switched from 18 to 20's.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
Yep I often get a vibration drone too on my td6 with 20s on (varies a lot with tyre pressures), when in traffic I always flip the gear to N.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35816 ![]() ![]() |
if you have a td6 Dalziel then you need to change your car profile... ... - .- -.
Well spotted Stan, nearly bought the V8 the week before but the visit to view and collect was a shocker! |
