![]() | Home > Technical (L322) > Maybe I'm being paranoid? (suspension drop) |
To me this is not unexpected. No hydraulic and pneumatic system is 100% leak tight unless they are very expensive systems. However considering the age of your car, it may be that the airbags (if they haven't been replaced since the car was built) start to leak, small hairline cracks in the rubber due to age and use.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
All 06>MY FF's drop over time when left... It is absolutely normal and as you said "it raised up immediately" so there is air left in it over time so not leaking... Don't give it a second thought |
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 ![]() ![]() |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
It does back first then front so that if the headlights are on it doesn't dazzle oncoming traffic. When you lower it, it's the opposite.
Beat me to it, Craig! 2006 4.2 SC
