Home > In Car Electronics (L322) > CD player
Bozzy1954
England 2003 Range Rover HSE 4.4 V8 Epsom Green
CD player
Hi anyone had problems with there cd player,? mine won't play and I can't get it to open.
Post #192270 6th Jun 2013 8:06am
hit it with the handle end of a screwdriver.. ... - .- -.
Post #192284 6th Jun 2013 9:10am
Bozzy1954
cd player
Right I'll give that a go cheers.
Post #192296 6th Jun 2013 9:46am
Budgie
This can occur if you've disconnected the battery with a CD still in the unit.
Sometimes a CD will get stuck when it retracts back into the CD cassette and, as Stan says, a tap with a screwdriver handle will normally sort it.
If not, then slid the door open and look at the right hand side of the cassette and you'll see the offending CD. You may be able to "persuade" it back into the cassette with a small electrical screwdriver. Wink
Post #192302 6th Jun 2013 10:30am
Bozzy1954
cd player
I can see the cd its stuck, tried hitting it no joy, I'll have ago with a screwdriver.
Post #192393 6th Jun 2013 6:29pm
warnster
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I have the same problem, spent an hour trying this morning with no luck, any other ideas would be much appreciated.
Post #192741 8th Jun 2013 6:03pm
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
i also have the same problem!
I heard all the cd's and in the last it not return to the 1st! I think it get stuck... but says NO DISCS.
I try to eject the and only ear a noise, but i can see the cd stuck.
I will try! Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #202672 6th Aug 2013 6:02pm
warnster
Mine is still stuck! Took it in for aircon re-gas so got them to take a look, they tried all the tricks but nothing and said they would have to dismantle the glove to get to it. It sounded pricey so left it for now, when I get time I'll have a go myself.
Post #202714 6th Aug 2013 8:27pm
goncalo
Once again thanks Stan
worked to me! the cd box is in my hand! Thumbs Up
nice tip! Ex-FULLFATTY now downgraded
Post #203350 11th Aug 2013 12:32am
Thumbs Up ... - .- -.
Post #203365 11th Aug 2013 7:52am
