![]() | Home > Technical (L322) > Bonnet release stuck on one side |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Are you sure its not releasing and not just stuck in the hole? 1st did they remove or re/align your bonnet? We have had a load of instances where bonnets will not open after being adjusted (or removed and refitted)
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
Thx Craig for the reply and suggestion... Will give it a try as you described to see if it opens.
By the way Craig, there are some rumors within the company I work for that I may be re-locating to the UK... If that's indeed the case I will look you up for a nice FF. Looking at the price differences for cars in the UK and the Netherlands I will probably be looking for a TDV8... |
No Problem sir |
My suggestion, let Gary get you a nice car and Craig make it beautiful |
Eugene, keeping the fingers crossed but it would definitely be great to pay less for a more recent model car... The freeking taxes they charge on cars over here is bloody robbery!! But nothing sure yet so have to wait to know more before we get to excited...
After checking out Wiki found the procedure to re-synch the mirros... The double tapping didn't do the trick so just kept tapping till I upset the ECU enough to reset the mirrors... |
Quick update on the original topic... Today went to my Indy trying to get the bonnet released again. Turns out the release pin of the lock on the passengerside (LHD) has some small plastic part which has broken off. So the release cable still works but due to the plastic part it doesn't release the lock. They could force the lock but then no way to keep it closed again till a new lock has been installed and since I want to keep driving the FF we decided to order the new lock first and then finalize the repair next week.
