Home > Maintenance & Mods (L322) > Brake flexi
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Brake flexi
Hi all!
Quick question(s) got to change my brake flexi this morning for the MOT. Does anyone know if I can just bleed that corner or will the full procedure have to be followed?
Also, is the brembo flexi, the same as the non brembo flexi?
Cheers! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #193268 11th Jun 2013 7:03am
If you work quickly and don't loose a lot of fluid you should just need to bleed that corner.
Somebodiy elses finger over the open end of the pipe helps.
A piece of plastic under the brake resevoir cap with the cap screwed back on should reduce the loss.
Just remember to remove it when you have finished. Thumbs Up
Post #193282 11th Jun 2013 8:31am
hoppy_70
This was quite an easy job in the end. To answer my own question for future searchers, the Brembo flexi is different. It has a banjo end instead of a screw end Shocked My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #193743 12th Jun 2013 6:47pm
