![]() | Home > In Car Electronics (L322) > VentureCam |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Hello roaldex and welcome.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35767 ![]() ![]() |
+1 what me learned friend has said your honour.. ... - .- -.
Roaldex Member Since: 20 Aug 2013 Location: Ramsbottom, Lancashire Posts: 2 ![]() ![]() ![]() |
Thanks guys. Have found the other threads with loads of info! Time to get a pack of rechargeable batteries and the soldering iron out, methinks! |
Just a thought ; you could pop a multi metre across the contacts in the charging socket and see if there is a current ,
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I've pulled the following quote of mine from a thread I contributed to a while ago, might be worth checking first as well...
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
i have just replaced the batteries in my cam as i had the same problem. |
