Home > Technical (L322) > Leak under engine
Brightondefender
Leak under engine
Hi there
I have just had my TDV8 running for about 15mins in the same stop and noticed a fairly large puddle underneath.
When I turn the heater off the water stops dripping - but with the blower on it drips away from 2 places under the engine.
Is this normal? Or is it likely to be the start of a leak? The car temperature is fine and running normally.
Many advice would be great.
Many thanks
Post #194595 16th Jun 2013 4:30pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Air con drain? Is water clear/odourless?
Post #194596 16th Jun 2013 4:39pm
Brightondefender
Hi yes appears to be - is definitely clear
Post #194600 16th Jun 2013 5:20pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Yeh seconded. This is probably air con condensed water. Try it again without the aircon on and it shouldn't do it. Perfectly normal and the more moisture in the air/ the bigger the puddle! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #194602 16th Jun 2013 5:34pm
Yes ^^^ air con drain. Very Happy
Try it without the ac on and it should stop. Totally normal all cars with ac will leave a little puddle. There is nothing that can't be fixed with a hammer😜😜
Post #194702 17th Jun 2013 12:54pm
