Home > In Car Electronics (L322) > Touchscreen 2006 FFRR Parrot SOT lead
jonbonnar
United Kingdom 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi guys,
New member here - hello to all.
Have owned and modded 3 x FFRR's over the last few years, so have some experience taking these vehicles apart.
I've done a lot of research on this, involving phone calls to Parrot, Autoleads, Nexxia and several installers...
Has anybody successfully integrated a Parrot to play music through all of the speakers with the Harman Kardon system?
Ideally want to use the parrot for telephony as the native RR system is clunky to say the least - having to pair with pin code every time I connect and no phonebook integration. Rolling Eyes
Thanks in advance...
Post #194720 17th Jun 2013 3:55pm
You could try a £65 upgraded Bluetooth Module from WIGGS should pair fine then....
Post #194721 17th Jun 2013 3:57pm
jonbonnar
Thanks, I've contacted Wiggs about it already, just want to get music from the iPhone through the HK stereo as well... 2006 FFRR, Zambezi Silver... considering another LPG kit...
Post #194723 17th Jun 2013 4:13pm
AUX....
Post #194724 17th Jun 2013 4:15pm
jonbonnar
OK, will search forum for where to find AUX input and crack on with that. Cheers 2006 FFRR, Zambezi Silver... considering another LPG kit...
Post #194725 17th Jun 2013 4:31pm
AUX input is in the rear of the centre consul under the flap.....
Post #194726 17th Jun 2013 4:48pm
If you have the RSE option Wink
TBH the best you can hope for without getting the Audio Connectivity Module is a good pairing from the BT unit Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194740 17th Jun 2013 6:26pm
jonbonnar
I don't have the RSE option unfortunately. Sad As far as I'm aware there is no option to stream music via bluetooth is there? I guess anoter option might be to install a digital TV tuner and hi-jack an aux input somewhere...
So just to confirm, nobody has successfully integrated a parrot into the denso touchscreen HK audio setup...? 2006 FFRR, Zambezi Silver... considering another LPG kit...
Post #194751 17th Jun 2013 8:07pm
