Home > Technical (L322) > Centre console removal
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I have a 2008 tdv8 and the steel gear surround has got quite marked. As a result I found a brand new gear surround which I hoped would be a straight forward fit. Looking at it, it appears to be screwed on from underneath meaning the centre console will have to come out to fit it. I've looked an can only find instructions for the earlier Brunel grey surround, which obviously doesn't come off the same.
Anyone got TIS for this model and could post me a pic, or at least point me at a starting area. I don't want to just start pulling stuff in case I break something critical! My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #195539 21st Jun 2013 7:35pm
Any help here?
http://www.fullfatrr.com/forum/topic17623.html .
Post #195560 21st Jun 2013 9:35pm
hoppy_70
Maybe joe. I'm on the ipad and such down loading is strictly forbidden by the apple gods...
Anyhow, I went ahead and had a crack at it. It wasn't that hard to be fair.
Remove the cubby liner (2 screws and some jiggling at the back with a plastic pry)
Remove the two screws under that.
Remove the side panels (piano back in my case) prise from the bottom out and up.
Undo the two screws this reveals
Remove the small oblong plastic panel under the clock (pops off)
Take out the two screws this reveals
Then pop it up from the cubby end, out of the pry clips and lift.
I didn't take the gear lever off, just manoeuvred it around it. Lift the panel whilst disconnecting all electrical connections. From memory these were
Two on cigar lighter. One on handbrake. One under buttons for terrain. One under gear indicator and the last under the M + - lights.
Six screws then hold the metal coloured bit down.
Fitted the new one, put it back together and .... Didn't work. Standard. The terrain response just faulted and wouldn't adjust. Took it apart again, checked connections and decided it needed coding to the car. Couldn't be arsed with that so swapped over internal electrics keeping all the new buttons and wheel.
Reassemble and hey presto! Works fine!
Mine was only cosmetic which is why i was able to swap the gubbins over. Looks great now with a shiny gear thingy!
Also, forgot to mention, the part was £45 on eBay. New genuine parts. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #195574 21st Jun 2013 10:41pm
For info, the later workshop manual (as per link above) shows full instructions on dismantling the new "floor console", Section 501-12 in the index, @ page 2768 .
Post #195581 22nd Jun 2013 1:12am
