Home > Technical (L322) > Front strut replacement - in pairs?
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Just a quick one chaps - the OSF airbag lost the will to live about an hour ago (air leak at the bottom of the bag, can hear and feel it and the car sat right down at the front). I've looked at the replacement process, doesn't seem any sort of big deal, but my question is, I guess if I'm replacing one I need to replace both at the front? Kinda painful at the price!!
Hoping I can get hold of some tomorrow and get it sorted.
Post #195646 22nd Jun 2013 6:28pm
Ideally only replace in pairs even though the other one "May" be functioning perfectly.
Post #195650 22nd Jun 2013 6:44pm
ebajema
Hi Cappo, I suggest to do both, I did and both bags looked in pretty similar (bad) condition although one bag started to leak (or at least that is what it looked like).
Island 4x4 seems to have the best prices and following recent reports over bad quality of the Dunlops, I suggest to stick to the Delphi struts.
Since the struts include the shock absorbers it is also better to replace both as have one new and one old one on the "same axle" may result in handling/safety issues.
Sorry for the bad news, I know what it feels like (and I had 200 GBP of shipping cost to Nig as well but no labour so that balanced it out a bit). MY 2010 5.0 SC Galway green and sand interior!!
Post #195651 22nd Jun 2013 6:47pm
Cappo
Thanks both - just as I suspected, and yes, the shock absorber aspect (and I guess generally making sure the two sides are "balanced") had occurred to me, hence the question.
By the time I've finished, I think I'll set up a suspension replacement specialist company - this will be the third car I've replaced front suspension on in about 5 or 6 weeks! (Others weren't FFRR by the way!)
Looks like Island sell the Delphi version so worst case I can get there on Monday if nothing else turns up in the meantime. Did drop Dan @ Duckworth a line just in case he's working late Very Happy
Does anyone know what make Bearmach sell/stock?
Post #195655 22nd Jun 2013 7:00pm
Doing both is usually recommended.
If doing it yourself, check the wiki for my howto Wink .
Post #195657 22nd Jun 2013 7:17pm
Cappo
Will do Joe, thanks - I found some American video on Youtube, looked pretty easy really, I wasn't sure whether it needed a plug in after to reset but the signs are not!
Post #195661 22nd Jun 2013 7:31pm
comports
And Dan @ Duckworths are the same price with free delivery Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #195663 22nd Jun 2013 7:33pm
mjdronfield
Got mine from Dan back in January. Same price as island 4x4 if I remember right.
When braking from 135 mph on the Hangar straight entering Stowe corner, you don't want unevenness !
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #195688 23rd Jun 2013 5:33am
Reformed
When I owned mine, I replaced only the blown side, to try and save money as it went straight after Christmas, but the following month, the other side did also go, so cost me twice in labour! (I chickened out doing it myself and got my then local indie to do it!) so would definately advise both, as has been said. Reformed
Post #195690 23rd Jun 2013 7:11am
As said above, would you change one spring or one shock absorber on a normal car? No... Then change the FF one's in pairs too... Simples Very Happy
Post #195715 23rd Jun 2013 10:26am
Cappo
Just another quick question - it may be on here in the search somewhere - but I've seen different views on which of the pipes on the crossover valve block you should slacken in order to release the pressure on the NEARSIDE bag? The offside is clearly not pressurised at all Laughing but the nearside may be. The car is sitting right down on it's knees, never seen it so low (I guess that's the self-levelling working against the burst bag) but I can't be sure there's nothing in the NSF bag.
Post #195921 24th Jun 2013 1:55pm
ebajema
When they worked on mine, I noticed that the hose is "relatively" easy to reach on the strut. So I suggest to loosen that to bleed the air off. Or just punch a hole on the bag, since you are replacing the strut anyway.
I don't like loosening hoses or piping if not necessary. If you're unlucky you can damage it and end up repairing more. MY 2010 5.0 SC Galway green and sand interior!!
Post #195926 24th Jun 2013 2:50pm
Cappo
OK, thanks, I'll have a look when I get it up in the air later on. Reluctant to punch a hole in this one when I could keep it as an emergency spare!!
Struts obtained, they are en route from Island 4x4 in my Dad's car as we speak. He said they had to lift them into his car for him, he couldn't manage it himself!!
Post #195929 24th Jun 2013 3:01pm
If they can lift about 1.5tonne then they wont be light wee things Very Happy
Personally i'd just lift the front end up and slacken the pipes off slowly with some fairy liquid sprayed on them to show the air starting to come out as you do it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #195932 24th Jun 2013 3:25pm
ebajema
I work in the offshore industry, we tend not waste time too much considering the daily rate of the vessels we use. I guess that shows in day to day life as well Wink
I remember them being quite hefty indeed Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #195933 24th Jun 2013 3:27pm
