Home > Maintenance & Mods (L322) > Steering Tilt adjustment: Problem fixed
I had a problem which was intermittent and then got worse whereby the steering wheel wouldn't lift up when you removed the ignition key, and wouldn't come back down to memory setting once the key was replaced again.
When I went to alter it manually I'd find the first touch of the joystick would make the wheel 'twitch' (for want of a better description) but wouldn't move, but if released and tried again, the wheel would move as normal. (The reach adjustment was fine)
It got annoying though having to do this every time I drove the car.
I thought I needed a new tilt motor and bought one as spare, however when I removed all the cowls and got to the motor, plugged the loom plug into the new motor the same problem was there. So I thought it might have been the switch joystick.
I unplugged and plugged it in a few times and I've come to the conclusion that I was suffering from a dry joint issue and a potentially loose contact. Since putting it all back together I've not had the problem and the wheel moves up and down as it should do. It also adjusts on the first touch rather than the second.
I'm keeping hold of my spare tilt motor just in case.
Sometimes, a fix just happens by accident, and costs nothing. Brilliant! Thumbs Up Discovery 4 HSE
Post #197248 2nd Jul 2013 2:50pm
And here's a link to how to remove the cowling around the steering column
http://www.fullfatrr.com/forum/topic19396.html Discovery 4 HSE
Post #197249 2nd Jul 2013 2:51pm
Budgie
Mine kept sticking at the top of the vertical movement and the only way to release it was to remove the cowl and put a spanner on the nut at the end of the vertical screw thread.
It's done this a couple of times now and rather than messing around with it every couple of weeks, I turned off the steering wheel memory function using my IID Tool.
I'm normally the only one driving the FF anyway and I don't have problems getting in & out without the steering wheel retracted so it's not worth worrying about in my book. Mr. Green
Post #197257 2nd Jul 2013 3:42pm
