![]() | Home > Technical (L322) > Easy opening |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
"Global Closing" I think is the official term.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
to get in when doors cable broken ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
^^good call one to remember if the central locking fails. There is nothing that can't be fixed with a hammer😜😜
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Does not work on mine... ,Must need switching on in the ECU 2011 Stornaway Grey 5.0SC Autobiography |
Have to hold it for about 5 sec. There is nothing that can't be fixed with a hammer😜😜
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
Mine doesn't do it either, I am told it needs coding |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Another good reason to own an IIDTool |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
Works on my 03 FF, opening and closing, cool |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
+1 for IIDTool - activated mine with it |
The term in the software is called Lazy Unlock and Lazy Lock and needs to be activated or deactivated. I use it a lot here with the heat and it is brilliant. It sheds a lot of heat from the car before you get into it and start strapping the kids in, drop the shopping in the back.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
WOOHOO!! Just tried it on my 54 Vogue TD6 and it works...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
this feature is documented in the owners manual...also for global open , insert the key into the drivers door lock and turn rearwards .... ... - .- -.
Yes Stan j know should have Rtfm. But didnt.
markyp Member Since: 05 Feb 2013 Location: essex Posts: 234 ![]() ![]() ![]() |
