![]() | Home > In Car Electronics (L322) > Front screen rolling picture when DVD playing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
if it was an old crt tv i would suggest turning the horizontal hold but as its a lcd then thats not applicable...is this problem when you are stationary or moving.. ... - .- -.
Taximan2011 Member Since: 15 Jul 2013 Location: Somerset Posts: 15 ![]() ![]() ![]() |
Both stationery and moving. The Tv Is obviously analogue as I get no tv picture although someone has put a digital tuner in the boot but doesn't seem to do anything but light up. But that shouldn't effect DVD operating New L322 Owner - |
it sounds like you have an aftermarket dvd setup and thats outputting a PAL picture which the fullfats screen isnt decoding as its NTSC...to see if this is the case i think you can go into the diagnostic screen and toggle to PAL but i'm not to familiar with the pre touch screen models.. ... - .- -.
Ok thank you for that advise I will have a look at that. New L322 Owner - |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
OEM DVD changer has option to change from PAL to NTSC in menu, get the wrong one set and you will get similar issue |
Screen is set to PAL New L322 Owner - |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Suggest working through all the options in the DVD player menu, maybe some "little fingers" have had a fiddle?
DVD on NTSC and front satnav screen on PAL New L322 Owner - |
