![]() | Home > Technical (L322) > Towbar swan neck |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
They should become loose I think, but may only do that when you push down the lever on the back (to make it think its in) and turn the handle. My Previous RR's!
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I can't believe that all that's holding my 1800kg caravan is a few ball bearings! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
i never felt that confident with mine... ... - .- -.
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Problem fixed. For those who are interested when you pull out and twist the wheel you can push in the ball bearings by hand. This confirms the towbar is good. Issue for me was then resolved by greasing everything so the towbar would sit in the correct position when offered up.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8098 ![]() ![]() ![]() |
It's more the 150kg of nose weight than the 1800kg ![]() |
