Home > Technical (L322) > Viscous fan won't dis-engage
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Hi All,
There is quite a bit written about this on the net but no real advice on what to do next............
My 2003 TD6 viscous fan is regularly engaging, especially in hot, slow moving traffic (as you would expect). It's quite a howl! Pedestrians stop in their tracks and turn around to see what is approaching them! The engine is much more lethargic with this engaged so I'm guessing it's also using a lot more fuel.
So if the fan kicks in, I can leave the car overnight and next day (i.e. cold) it is still engaged and you can drive it all day and it will stay on. The knack here to dis-engage it is take the revs to about 4,200 RPM at which point it dis-engages and unless you hit slow moving traffic and lots of heat again then it stays dis-engaged.
I am guessing I need a new viscous coupling?
Any thoughts or advice pleaae? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #199261 17th Jul 2013 6:43pm
Flashman
Yep, very common fault with Range Rover and BMWs. Mine always engages when the engine is hot in hot climates and I always high rev it a bit to get it to switch off.
Some on here remove it completely as it is not really needed in UK climates (although in current conditions it may be).
Removing it and cleaning it out / oiling it might help, otherwise you need to get a new one. They seem to sell for about £150 or so. Tom
Current Drive
Previous Drives
Post #199262 17th Jul 2013 6:48pm
Yip new viscous coupling or run it in this weather and just leave the AC on and you have enough to cool the engine as long as the cooling system is in good nick Smile Its more for the very hot climates and lots and lots of slow moving traffic really.
Plus it never fully disengages anyway so still spins at any temp drawing air over the engine and power from it so in winter it makes it take that bit longer to warm up so means the FBH works a little bit longer and harder to counteract it a bit so more fuel wasted Smile Mines been off over a year now without any adverse affects Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #199294 17th Jul 2013 8:58pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Driving in south of France at the minute , high 20s temps. I have my coolant temp showing on hidden menu, it's been reading between 88-100degrees depending on terrain, included some big motorway hills . Typically 90-92.
The viscous fan is on most of the time, with the distinctive whoosh. Would you expect it to be engaged most of the time in these conditions? 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #273234 28th Jul 2014 1:28pm
Most likely as thinner air offers less cooling and if the engine is working hard it will be hot. the AC fan is more than able to cope in most conditions without the viscous unit IMO. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #273241 28th Jul 2014 1:53pm
SKOT
As per my original post, if I red lined my TD6 (which I had then) the fan would invariably disengage after a lot of howling!
I am sure that piece of technical advice will not be recommended by all here but if it does disengage it answers your question! 2006 4.2 SC
Post #273242 28th Jul 2014 1:57pm
Yeah but the TD6 should redline every now and again anyway to clear the soot from the exhaust regularly anyway and help clear crud from the exhaust turbine vanes/housing that builds up Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #273251 28th Jul 2014 2:52pm
I had a TD6 in Scotland and was constantly having to rev the engine hard after re start or next morning after towing something to get the viscous fan to dis-engage , I now have a supercharged in WA ( and I don't have to tell you how hot it can get ) and hardly ever hear the thing kick in so I would have to say its a minor failing of the BMW desiesel . 2008 MY Supercharged
Post #273256 28th Jul 2014 3:24pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Don't rev it to max!! The fan is designed to run at below engine revs, it may disintegrate with the disastrous results, tales of blades puncturing the bonnet!
Post #273288 28th Jul 2014 6:50pm
Just remove it Thumbs Up
Mine has been coping fine with the hot UK weather (up to 30 degrees C), solid as a rock temperature wise. .
Post #273344 28th Jul 2014 11:30pm
TOF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Is this an easy thing to remove... It is really starting to annoy me and is so loud. I only have to be in traffic for a couple of mis and it is wooshing all over the place...
Post #293805 17th Nov 2014 9:23pm
Easy to remove? If you have the right tools. You will need a couple of viscous fan spanners, recognition that it is on a left handed thread, and some patience to release the fan shroud. .
Post #293838 17th Nov 2014 11:08pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Did mine ... see link below for some tips
http://www.fullfatrr.com/forum/topic27551.html
Also forum search viscous fan has many links Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #293840 17th Nov 2014 11:47pm
TOF
Is it ok to do it on an 06 supercharged or will it mess up the air con...
Thanks for the info
Post #293869 18th Nov 2014 8:55am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
The visscous fan on the Supercharged also has an element of ECU control so it will screw things up if you remove it..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #293870 18th Nov 2014 9:12am
