![]() | Home > General > Odd noises |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
I know I am a perfectionist but I have noticed a few things about the TDV8 that I didn't have in the TD6, they MAY be faults or they may just be results of a different build.
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
I have a similar set of noises coming from the dash area - I have presumed it's all to do with the vents opening up as the engine has become warm enough to circulate air into the cabin. May be totally wrong though.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
That would drive me crazy. Take it back! ![]() I won't let my Dad ride in the Defender because he is heavy and the passenger seat frame creaks all the time... |
Shaun the Sheep Member Since: 21 Mar 2010 Location: Bolton, Lancashire Posts: 48 ![]() ![]() ![]() |
I to have an annoying noise from the front passenger seat, it's not there all the time and it seems to be intergrated into the speedometer and since being installed it also added speed camera warnings into the sat nav, and also added shoe shops as points of interest! |
That's just reminded me of another noise I get, or rather, a noise that only happens when my mate sits on the car. He's the same build as me (slim) but when sits in either the driver or passenger seat the seat belt anchor rubberised part rubs and squeaks on the seat leather. No one else can make it happen! He's jinxed |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
Maybe they're all the same...
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
Same here with the creaking dash RRUK. I've put it down temp change. Usually I will give the dash a firm push just above the speedo before I drive off. Seems to help. Had a BMW that did the same thing.
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
RRUK - I know you've changed your car to the bad bomber but did you ever get the issue above sorted. Mines doing the same and it's driving me insane even though I've told the dealers twice about it with no result. They wouldn't take the bigger souce of constant noise that sits there either, not covered under warranty apparently!! MY11 Vogue 4.4 TDV8 - "African Queen" |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 ![]() ![]() |
The creaking is indeed the vent motors inside the HVAC - my dealer sorted this by replacing them while fixing a vibration from one other motor.
Blimey, this was SOME time ago!
@RRUK - thanks for the info and pointing out a potential LTB, will mention it to the new dealer I plan to use.
