Home > Technical (L322) > Rear Wiper Arm Removal - How To ?
TugRR
I may be making a "school boy error" here, but I can't remove the rear wiper arm . . . It appears to be a bit more than an interference fit - Any tips ?
I need to take it off to sort the washer nozzles out. After having discovered water is rushing to the in line one way valve (which is U/S) and there's no problem at the motor, it looks like the nozzles are blocked. The "poke it with a needle" method partially worked on one of them.
Any tips gratefully recieved - I don't want to break the rear glass !
Thumbs Up Where do you go after one of these . . . ?
Post #201524 30th Jul 2013 2:07pm
it is an interference fit on splines so yours sounds like its stuck...you could use a wiper removal tool or persevere with a bit more grunt.
http://www.fullfatrr.com/forum/topic19225....rear+wiper ... - .- -.
Post #201528 30th Jul 2013 2:16pm
TugRR
Ta, Stan - I've whizzed the roof spoiler off, so access is best. But I don't like the idea of alot of force with all that glass around Shocked
We'll see if anyone else has a eureka idea . . .
Post #201530 30th Jul 2013 2:19pm
WD40
You'd be amazed how capillary action will suck it up into the splines, and it's easy to clean the glass afterwards. Discovery 4 HSE
Post #201535 30th Jul 2013 2:51pm
TugRR
Thanks - I'll give it a whirl !
Post #201554 30th Jul 2013 5:00pm
Mr Tee
Just done mine, it'll take a bit of brute force ! Keep your eyes peeled for the plastic nipple that sits in the hole, mine fired off down the drive , put it all back together and the water was peeing out fro the spindle.
Post #201563 30th Jul 2013 6:37pm
edward.barry
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
Poweruk havee a good tutorial on the tube, worth a look. Laying in hospital too lazy to dig out. Link, easy fount though, showschow to remomo er spoiler as well. 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
2005 Subaru Legacy Outback (the wife's)
1981 2.5 Opel Commodore
Post #201622 30th Jul 2013 9:21pm
JPJ64
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Excellent advice on here (as usual).
Watched the PowerUK video, pulled the plastic cap off, and mine was pretty much gunked from the NRV to the nozzles! Fortunately after half an hour with a needle, hot water, compressed air aerosol, both jets are now functioning perfectly. Top tip, a used beer bottle and some gaffa tape make a suitable container to convert this into a single handed job as it was ‘too cold’ for the Memsaab to come out and help.
Post #462322 27th Dec 2017 3:58pm
