Home > Duckworth Parts > Bike carrier and detachable tow bar |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
Hi
2nd Aug 2013 9:44am |
wanderer Member Since: 10 Nov 2012 Location: Wandering Posts: 178 |
Dan.
2nd Aug 2013 8:01pm |
You can paypal direct using - www.paypal.me/duckworthparts
5th Aug 2013 8:42am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Is the armature available on its own Dan? |
17th Aug 2013 2:35pm |
yes certainly is cost £312inc vat You can paypal direct using - www.paypal.me/duckworthparts
19th Aug 2013 9:31am |
Sorry - bit confused here - the Westfailia part number is A50-X D164,4 Si50
19th Aug 2013 10:09am |
so you don't require the tow armature.
19th Aug 2013 10:31am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7785 |
Sounds like he has the armature - and has the removeable neck - but is missing the detachable mount that bolts into the armature. |
19th Aug 2013 9:47pm |
if its the highlighted bit below then unfortunately not available seperate
20th Aug 2013 11:43am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
if you just require the swan neck holder, ie the part that goes into the square hole, then try some of the range rover breakers, on ebay, and ask them, as these are more common than the swan neck itself, they get left in the garage, and eventually on ebay, the holder only requires a pin pulled out, and gentle presuasion to slide out.
20th Aug 2013 11:59am |
