![]() | Home > Technical (L322) > Where does temp gauge sit on first start up? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I'll go and check - in a couple of months. ![]() Seriously, I could check now for you but it's 34°c outside. |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Mine does a full sweep from cold to hot on start up then settles back to the start of the blue and moves up as the temperature rises (I have a 56 TDV8).
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
When I start the car, TD6, the temperature gauge stays at the bottom of the gauge and only moves up as the engine temperature rises and then sits at just left of vertical when the engine is hot.
