Home > LPG > Won't start on petrol
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Hi I have a 2002 on lpg and the switch won't turn to petrol from gas.
Last week I ran out of petrol completely and the car started and ran on gas no problem, the next day I filled up with petrol and everything seemed ok.
On a trip back home the next day I ran out of gas and it automatically runs on petrol but the switch keeps beeping and flashing, I have pressed the switch but nothing happens.
Now when I have both tanks topped up but when I start it starts on gas straight away.
It did it at 4am this morning from cold.
Thankfully the beeping has stopped.
Is there a reset or diy fix.
Ta
Post #202260 4th Aug 2013 10:37am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
sounds like you need a pro to have a look really.
why not take it in to whoever does your LPG service?
Post #202271 4th Aug 2013 11:25am
Mph28mph
Only had it six weeks.
Need to find a good garage near Wigan. Seen an advert for a guy in Adlington
http://www.adlingtonmot.co.uk/
Anyone used them and have feedback
Post #202275 4th Aug 2013 11:51am
SoggyBottoms
a normal garage won't help, you need an LPG specialist.
what system do you have fitted? you can then check out the importers site for local support
Post #202295 4th Aug 2013 3:17pm
Mph28mph
LPG Conversions
16 Huyton Rd
Adlington, Lancashire PR7 4HJ
Wrong link posted
Post #202297 4th Aug 2013 3:56pm
SoggyBottoms
place looks professional, good reviews.
Post #202307 4th Aug 2013 4:54pm
D16XEY
Scotland 2003 Range Rover Vogue 4.4 V8 Java Black
I had a similar problem but it turned out to be the fuel pump in the tank had failed,
Post #219578 29th Oct 2013 8:54pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
http://www.lpgconverter.co.uk/item.php?id=193&dir=31
Yes as above, ask for John. He is very good.
Post #219581 29th Oct 2013 9:10pm
paneldamage
They don't like running out of petrol as the pump will continue to run dry and eventually overheat, at least that's what happened in my Classic a few years back Embarassed think bout it: in a normal set up, the car stops when the go-go juice stops a comin... So the pump stops
Not so when it s on LPG Big Cry
Post #219601 29th Oct 2013 10:38pm
