Home > Maintenance & Mods (L322) > transmission oil cooler change out |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
changing out this little cooler on my s/c - well the quick connect /disconnect on the lube oil supply return lines is anything but!!!
5th Aug 2013 9:46am |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
On the engine oil cooler (similar fittings), there is a little plastic dismount tool - looks like a split plastic collar - that you unclip from one side of the fitting, turn over and refit so it slides into the 'teeth' of the clip, enabling it to be pulled free. Not sure if it could be useful here, but i thought it worth mentioning .... |
8th Aug 2013 11:48pm |
Cheers guys - they weren't as damaged as first thought and I managed to straighten them out and refit , but added the extra security of safety wires as an extra back up. All tested and leak free. |
9th Aug 2013 8:35am |
