Home > Technical (L322) > BONG!! Transferbox Neutral Gremlin
I had the Transfer Box Neutral bong on Monday coming back from the Highlands, it all happen so quickly I almost missed the message. Nothing untoward's when driving just the bong and it happened a couple of hours into the drive so the new battery was well charged up. Must try my Hi/Low switch to make sure that it still works
Post #225436 26th Nov 2013 10:16pm
Just been out and operated the Hi/Low switch and it worked 5 or 6 times then stopper working. Switch the ignition off and back on and it worked again so I suspect a dirty connection somewhere
Post #225444 26th Nov 2013 10:48pm
paneldamage
I think it is limited to 5 operations in succession 47p2...... To stop the motor overheating. There is a lot of this type of protection built into the ECUs on a L322. Turning the ignition on and off resets the ECU.
Post #225445 26th Nov 2013 10:53pm
Ok thanks, will try it again tomorrow and see if it throws a wobbly after 5th attempt Thumbs Up
Post #225449 26th Nov 2013 11:04pm
daveturbo
Bong
My 2003 td6 vogue ,was coming up transferbox neutral and bonging now and again,it would not go into low range. So with nothing to loose i removed the transfer box motor,three bolts then on a bench took off the side domed cover two torx. I cleaned the contacts and put back together,be careful when putting on the cover as the magnet can pull the four sprung loaded contacts off.powered up pins 9 and 10 the closest pins on the plug next to the domed cover in any order and my motor spun up, realign the master spline and refit and mine now works great low to high and no more messaging thank god,i now put it into low/high once every two weeks to keep it in use.Hope this is any help. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #227093 4th Dec 2013 11:21pm
