![]() | Home > Technical (L322) > Balls! |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Anyone know how tight the ball joint nut should be? I've replaced the upper suspension arm (the one with a separate all joint) and the crappy pram sound seemed a bit worse if anything |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
Should nt need to be mega tight. 48nm is pretty "nipped up'
Maybe I need an air ratchet.... I hadn't even thought it might be turning. Hopefully not as its tapered AND has the car weight on it. I'll update tomorrow if its worked. The manual says it should be 60nm. I'll try that if it doesn't work. My Previous RR's!
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
If you snap it when tightening it up then you won't need to worry about it napping whilst driving. |
I hope it doesn't snap! It isn't an expensive part but doesn't look like its going to come out without some sort of special tool. I think it's pressed into the hub (I only replaced the arm and bush) My Previous RR's!
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Yeah, fair point the full weight of the car on the taper should hold it pretty snug. Hope you get it sorted!
