Home > Maintenance & Mods (L322) > Fitting a detachable tow bar |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
i think the 300nm might be wrong..thats more than twice the torque for wheel nuts.. ... - .- -.
6th Aug 2013 7:11pm |
wanderer Member Since: 10 Nov 2012 Location: Wandering Posts: 178 |
Stan
6th Aug 2013 7:15pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
300Nm on the actual towbar receiver is probably right although 300Nm is a LOT! |
6th Aug 2013 7:21pm |
Thanks Weejock
6th Aug 2013 7:25pm |
this is from the workshop manual and it does say 300nm,
6th Aug 2013 7:26pm |
Editted my last post after I realised what you were referring too, the actual towbar armature instructions I had were wrong. 300Nm on the receiver is probably about right. I struggled with 250Nm on hub nuts before so as long as it's above that I wouldn't be too concerned. |
6th Aug 2013 7:31pm |
Thanks guys. So basically give it a lot of force on my breaker bar should be about right! |
6th Aug 2013 7:34pm |
If you have a 2 ft breaker bar, its pretty much the same as a 60kg on the end of it......ish.
6th Aug 2013 7:44pm |
