Home > Maintenance & Mods (L322) > Heated steering wheel problems |
mark1959 Member Since: 28 Aug 2010 Location: North West Posts: 9 |
OK so no replies !!! Nobody else with the same problem?
22nd Aug 2013 6:22am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
There's a small ecu / control box in the lower half of the steering wheel tray. You must have unplugged it to change the wheel... That will be at fault for sure...
22nd Aug 2013 6:31am |
Sorry not the fault everything fully plugged in. All connections also checked by an Indi RR mechanic he wonders if there is an ECU patch required? He says he has asked but keeps coming up blank!! |
22nd Aug 2013 6:59am |
I didn't mean the fault will be its unplugged! It's probably in need of changing... |
22nd Aug 2013 7:07am |
Thanks !!!! Replacement ECU currently on way to me................ I will let you know.
22nd Aug 2013 7:28am |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
Hi This problems has just developed with my heated steering wheel. Did resolve the problem? |
10th Oct 2014 4:41pm |
Him Yes I changed the ECU itself, non-repairable, and everything is now fine. The ECU is no longer made you will need to find a second hand one. I had to buy with the steering wheel from a scrapyard, they refused to split. |
11th Oct 2014 12:57pm |
Thanks, I will need to have a look around. Where is the ECU, In the steering wheel cover? |
13th Oct 2014 8:00am |
