Home > In Car Electronics (L322) > Digital TV Tuner
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Digital TV Tuner
The previous owner of my 2003 4.4 Vogue fitted a digital TV tuner in the boot which includes a USB input with an ipod connector, however I have been unable to get it to work on the LR Sat Nav unit (the sat nav unit doesn't even seem to register that it's connected when you go into television mode). I don't have the handbook for the TV tuner and it's not something I've had any experience of in the past so not really sure what I'm doing Whistle Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #204645 18th Aug 2013 1:05pm
mjdronfield
Is there an "Aux" option when you are going through the channels, or AV or such like ?
Don't have this setup myself, just thinking aloud........... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #204648 18th Aug 2013 1:52pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Hi - I have a similiar set up - is your digital TV receiver gold in colour?
Anyway - silly question but my digital tuner has to be turned on by the power button on the remote control each time the ignition has been turned off - I also have to have the TV screen set to AV rather than channels 1 - 30. If the car TV is showing a channel number just cycle through the channels until you see AV. Hopefully that should get you the main menu for the digital tuner.
If you then get it to power up and its a GKD system I can scan you a copy of the manual.
Failing that - check the Video and Audio out cables run into the audio in and video in cables on the car original TV tuner and there is power going to the digital tv tuner. I suspect ths issue is either the wrong programme on the TV screen or the tuner isn't actually powered up. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #204693 18th Aug 2013 9:07pm
andy180
Thank you for your responses Smile
After rather a lot of messing about my Television is now working Smile I also worked out how to connect my ipod up via the digital TV tuner which is fantastic Cool Not sure how often I'll use it though Whistle Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #204817 19th Aug 2013 8:48pm
