![]() | Home > Group Buys > flip keys [New Order Oct 2014] |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
mustard can you take a photo of your to keys, it will have to be a good quality and close up.
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 ![]() ![]() |
Ok so took the guts out of the original key, went out to the motor and put the key into ignition, no clicks as expected but it did turn the ignition to position 1, no further as its solid at that position. I put it all back together and tried again, everything back to normal again.
Key slides into ignition with no issues at all, I only get the click from the ignition if the transponder is in the flip key
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
To me it looks wider and the groove near the tip looks straighter?
Synced on the first try, now just need to do the blade as the old transponder is also on place.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
That looks like a terrible cut of the key - it looks wider and the top end (the final straight bit) is longer on the cut - I think the cutting machine (or operator) wasn't set up right. |
the key was cut by a baffoon, the cut is far to long, on the ignition lenght is critical, all you can do with that is take some of the end of the key to get the tip and the start of the cut lined up.. V8 facelift Range Rover Autobiography 22" wheels.
OK so its a turd cut, getting somewhere |
stormindes Member Since: 20 Oct 2013 Location: United Kingdom Posts: 13 ![]() ![]() ![]() |
Hi Daveo, do you have any 'spare' flip keys left over? Only asking as I have an 03 Vogue with only one key and I would like to increase my chances of being able to use it when I eventually loose that one key |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
ok guys major problems hers.Key cut and transponder in but under no way is syncd.Procedure i follow
believe my above message bit confusing so reposting
hi mate,,, ok try the sync process in doors not in the car so you get it right, press the bottom key it will flash then starts to flash fast,keep it pressed,,, at this point you then press the top button 3 times, do the 1,2,3 mississippi thing then relese both buttons..you are looking for the 3 long flashes, get this right then try in the car... V8 facelift Range Rover Autobiography 22" wheels.
with the chip,please make sure there is not an unprogramed one in there, i thought i removed them all but i did over look a few, hold the chip near the ignition you should here the click,if so pop the new key in and try turning but dont start just put ignition lights on then off... V8 facelift Range Rover Autobiography 22" wheels.
Good day Dave.Thanks your last.Yes unprogrammed chip was in.Took it out and now flip key unlocking steering wheel/turning to position I
