Home > Maintenance & Mods (L322) > Testbook needed to reset ABS after changing brake pipes ? |
Rave says that if you disconnect any brake pipes at the ABS unit you need Testbook to reset / fix things
1st Sep 2013 2:53pm |
So what is the "brake modulator" ? Is it the block in the engine bay next to the diesel cooler rad with all the plasctic coated pipes going in and out of it? If so I will only be doing the pipes going from it to the wheels, so shouldn't need to worry?
13th Dec 2013 5:12pm |
Never needed to use Testbook or anything else when I replaced my brake pipes last year |
13th Dec 2013 5:31pm |
If you disconnect any pipes from the modulator block there is the risk fluid will bleed out of it and let air in.
13th Dec 2013 5:57pm |
Thanks guys.
13th Dec 2013 6:17pm |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
I had the engine light come on after replacing the calipers as there was still air in the system. |
13th Dec 2013 6:34pm |
Yes I run the new pipes into the modulator block and bled the system using easy-bleed without any faults showing up |
13th Dec 2013 7:09pm |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
I have also changed my brake pipes from the modulator, albeit only the fronts but did that and bled the old fashioned way with no issues.
13th Dec 2013 7:18pm |
That's all good news
14th Dec 2013 3:07am |
Are all the nuts. unions and connections 10mm / 3/16" pipe and are there any special connectors (am thinking of the banjo one at the rear end) ?
14th Dec 2013 1:01pm |
Well I have been getting all the pieces together, parts and tools for brake pipe swap.
11th Jan 2014 2:05pm |
Nice bit of kit, remember to put the nuts on the pipe before you flare it |
11th Jan 2014 5:32pm |
You know I am going to forget don't you And it'll be the big long one from front to back! Best I do them first and concentrate .
11th Jan 2014 5:34pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1244 |
I think the reset of the abs is esssentially a case of firing the solenoids in the abs block so that they push fluid through them to purge the air out.
17th Jan 2014 4:40pm |
