![]() | Home > In Car Electronics (L322) > starting Headunit takes forever |
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 ![]() ![]() ![]() |
Hello
Someone is bound to say it so I'll go first , have you checked your battery voltage ? I have no other ideas but always the first place to start with any thing not running quite right . 2008 MY Supercharged
the battery is fine. (checked by the dealer) and their is no power consumption when the car is shut down.
Car running: 14.9 Volt
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8767 ![]() ![]() ![]() |
yes, that sounds ok.
mhh yeah I will try that. battery was dissconected for the alternator but I dont think that the dealer put the 2 cables together to do the reset. |
right now the problem is fixxed. (I did the battery procedure and hold the two clamps together)
