Home > Technical (L322) > Yet another EAS question
J90
France 2006 Range Rover Vogue Td6 Java Black
I have tried the search function before asking this.
My EAS will not lower to access mode or rise to off road height. There are no bongs or control check warning messages and the flashing indicator light on the control does activate but only for a couple of seconds and then stops.
The car has just returned from having the auto gearbox fluid and filter changed and a problem with the bonnet catches rectified. I only noticed the issue when I tried to lower the car whilst on the drive today. Other than that I have not noticed anything else detrimental so far about the EAS. I did check the off road view on the touch screen and all the wheels are 'level' when moving or stationary.
Any thoughts chaps?
Ta ....
Post #210992 18th Sep 2013 9:27pm
Hmm, will the height change with the bomnet open under usual circumstances.....?
I wonder if the bonnet closure switch is not catching properly after having the new catches fitted..... It thinks its open and wont change height?
Just an idea. There is nothing that can't be fixed with a hammer😜😜
Post #210996 18th Sep 2013 9:36pm
J90
That thought crossed my mind as well. I'll wait until tomorrow morning, pop the bonnet, give it a good slam down and try the EAS again.
I can live with the car in standard height mode for now but would like the EAS to work fully. I'll update the thread tomorrow.
Ta
Post #210998 18th Sep 2013 9:47pm
Think there are probably some rubber adjusters which maybe are holding the bonnet a bit high. There is nothing that can't be fixed with a hammer😜😜
Post #211001 18th Sep 2013 10:02pm
TugRR
Chris - I had similar with my 06 MY Td6 when I first got it.
I can't remember the exact fix but believe it was something to do with a filter on the compressor being blocked. This compressor being different in design to the earlier models.
Perhaps worth a go ?
Thumbs Up Where do you go after one of these . . . ?
Post #211004 18th Sep 2013 10:28pm
TugRR
http://www.fullfatrr.com/forum/topic4319.html
Post #211005 18th Sep 2013 10:32pm
J90
If it,s not the compressor filter but still a bonnet issue even after adjusting the rubber adjusters, can a iid tool reset the EAS back to normal so that I have the access and off road heights?
Ta.
Post #211060 19th Sep 2013 11:39am
J90
EAS back to normal. It was the bonnet not closing properly.
End of thread.
Ta
Post #211113 19th Sep 2013 4:30pm
Useful to know that the bonnet blocks/locks the EAS (even thought the tailgate doesn't - like it did on the P38A)
Where is the switch on the closing plate? .
Post #211129 19th Sep 2013 5:46pm
J90
Unfortunately J90 No.2 cant assist the real Joe90. I just popped the bonnet and gave it a good slam down and it seemed to cure the problem Smile
Post #211136 19th Sep 2013 6:44pm
Very strange... Rolling Eyes
Post #211191 19th Sep 2013 9:59pm
