That is both arms done, it seemed so easy to start with but both ball joints were a nightmare.
Broke my screw type ball joint separator and had to get a fork type separator and batter it with a 20lb sledge hammer to get the joints to separate.Took 1/2 an our to do one side and over an hour to pop the ball joint on the other side.
Also sheared off the 10mm fixing for the height sensor on the drive side. Hopefully I can get one from the local stealers, held on with a 10mm bolt at the moment. All the other bolts came apart easily.
How have others who have done their front lower arms managed to tighten them with the vehicle back on the ground, I had to use about 4 extension bars as my breaker bar was too long to turn under the vehicle 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
