Home > Maintenance & Mods (L322) > TD6 '02 FFRR Rear Subframe Bushes Replacement
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
As mentioned earlier, the only challenging part was removing the old rivets. Besides that, it is a manageable task. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #672172 28th Aug 2023 4:11pm
Cymraeg
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Much obliged
Post #672194 28th Aug 2023 8:29pm
kevinp
I'm doing mine in 3 weeks time and thinking of grinding the rivet heads off and knocking them into the bush. Thumbs Up
Post #672208 28th Aug 2023 9:44pm
kevinp
Just done mine.
Put it up high on axle stands.
Small trolley jack under each rear hub and just take the weight.
I then removed all four bolts.
Slowly lowered one side but the shock was at full extension and wouldn't allow the subframe to drop enough from the body. Removing the lower shock bolt let the subframe drop nicely to allow enough room to get the remover onto the top of the bush.
Did one side, jack the hub back up and did the other side.
If it's putting anyone off, you don't have to remove the exhaust. I didn't even have to unclip hoses or wires and didn't deflate suspension.
I had to pack out the top insertion tool to allow the bush to fully seat. Thumbs Up
Post #675365 12th Oct 2023 5:35am
pcourtney
OMG super info and thank you Joe !
Post #697906 12th Aug 2024 4:29pm
