Home > Maintenance & Mods (L322) > Its stopped again :(
Deasy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Hmmm,
so we were having quite a good run with the rangie recently.
And then it happened, my brothers X5 gearbox gave up, all revs no drive. so considering the amount of stick i get about the reliability of my rangie and how reliable his x5 is i thought id give him some stick back.
Great fun, until i get a call off the wife. Our car wont start Sad great, im sure it has done it so it doesn't feel left out!
so the issue i have, it turns over fine but just wont fire up.
Read a few posts, so i checked the fuse / relay - both fine.
I have ordered a new fuel pump and fuel filter / pressure regulator just out of caution, so will get them changed anyway.
But the think that's confusing me is
1) I don't have a warning light and only 3 codes, bank 1 running lean, bank 2 running lean and purge fault?
are they all low fuel pressure related?
2) i cant even get it to force start on gas? just does the same thing, but could have shut down the sequential system because there's no fuel pressure??
3) i cant even move it, had a few of us trying to push it with it in neutral. at the risk of sounding daft, is it not moving simply because its so heavy? i have never tried to push an auto before. PITA as is blocking the other car that's on the drive Censored !
Any help would be greatly appreciated
Thanks Thumbs Up
Post #213890 3rd Oct 2013 4:18pm
mjdronfield
Fuse 37 in the glove box puts the transfer box in neutral for towing purposes.
I think if you put a 5A fuse in it (it should be empty now) the transfer box will go into neutral. There will be a corresponding message in the instrument cluster.
May help you to move it..........
Can't help with the other stuff, as I've a diesel.
Good luck 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #213909 3rd Oct 2013 6:59pm
Deasy
Hmm, il see what happens when I have time to look at it.
But good news, Well I managed to the 3ton lawn ornament enough to get the disco out so can go greenlaning this weekend .....
Post #213923 3rd Oct 2013 8:09pm
